PVC conduit run under deck.
Hi,
Can PVC conduit be run over the ground if it is underneath a deck instead of burying it? Also, could it run alongside and be attached to the side of a deck?
Thanks!
Thanks!
Originally Posted by CRJ
Hi,
Thanks!
Thanks!
The deck is about 8'x8'. From grade to bottom of deck joist is 6 to 8 inches. Conduit is schedule 40 PVC 1".
Where do you live? You may have to use an expansion fitting. Is the PVC conduit run between securely mounted items such as boxes, elbows, or conduit terminations?
This is in the Pacific Northwest, in the general Seattle area. Very mild climate. What are the specs on expansion joints? Is it different for schedule 40 versus 80? I do have them on the 40' - 50' sections that are in the afternoon sun.
This section of the run would go about 8-10 feet under the deck, that would also be the distance of the straight portion. I could fasten it to the undersides of the joists since the deck will get rebuilt. After it emerges from under the deck, it would then be going down into a trench that would be under the yet to be built hot tub slab. Just trying to keep to the most direct route and minimize the ditch digging. Is 24 inches under the slab bottom sufficient? I could easily switch to the schedule 80 as this is section between the GFCI breaker shutoff panel and the stubout for the hottub.
Thanks!
Thanks!
