Putting up ceiling fan
Electrical box
I was putting up a ceiling fan by mounting it to an unswitched ceiling box. I noticed that a when I used a tester on either one of the black or white wires and also the box itself, there was a reading which indicated that the box was live. What could be causing this?
Francl,
The box is probably not grounded, and you are seeing phantom voltage. Try testing against a known good ground.
Also, you should probably have started a separate thread, not added to this one.
