How do I use feed thru lugs
More lug questions. What exactly are feed thru lugs and how do I use them. Is there something I can bolt onto the main buses or is that what feed thru lugs are. sorry for all the lug questions, but every GE, Culter, Square D catalog I have doesn't explain things this basic. All my electrical course/text books just mention meter/combos as examples.
Like Jedi9 said, there should a lug at the bottom of each hot bus, if the panel was designed to feed through. However, in my experience I have only heard these referred to as "sub-feed lugs". Some mfr's offer a sub-feed lug kit. Ordinarily these are used to feed a sub-panel when you are out of breaker spaces. I agree that the sub-feed lugs are protected by the main breaker.
Juice
Juice
