help me!
Old 02-22-05, 04:10 PM
mauryburnett
help me!
I have a problem with a circuit...none of the lights nor plugs work but there is power going everywhere (through the hot and the neutral) It is the strangest thing I have seen!
I've hot wired switches to directly power up the lights and no avail. I was working on some unrelated wiring when it went down.
Any questions I should be asking myself???
Old 02-22-05, 05:02 PM
Sounds like an opne neutral. Problem is in the last working device or first not working device. Problem could also be in the main panel.
Old 02-22-05, 05:17 PM
Agreed. Classic open neutral.
Old 02-23-05, 05:54 AM
Mr Fixit eh's Avatar
Mauryburnett says,
How did you test? Take an analog VOM or a 2-lead neon tester. Test between hot and neutral and then between hot and ground. If you have 120V between hot and ground but 0V between hot and neutral, you have an open ground condition. Test between neutral and ground. You should have 0V.
If you tested with a tick tester you may be reading phantom voltage.
Maury says,
What exactly did you do?
Post back with more details.
Old 02-23-05, 06:39 AM
I disagree. I still think this is an open neutral, especially if you get 120 volts between neutral and ground, which I suspect you will.
Old 02-23-05, 09:19 AM
Of course John's right. I was typing too quickly.
