15 amp 2 pole,20 amp 2 pole
Old 02-25-05, 03:59 AM
PugGuy2001
What are the disadvantages with the 15amp & 20amp 2 pole murray breakers. I ran out of slots on my 150amp service panel. Can I still run 10 recptacles on a 20amp 2 pole. Will either of these 2 poles trip more often? Are there any limitations on either the 15amp or 20amp 2 pole breakers?
Old 02-25-05, 05:26 AM
For a residential system in the US there is no limit to the number of receptacles or lights on a circuit. Forget that 10 rule, as it is not a rule. Receptacles and lights do not increase the load on a circuit, only plugging something in *and using it) and/or turning on the light increase the load.
Tandem breakers give you two breakers in the space of one. If you use a 20 amp tandem breaker then you can run two 20 amp circuits from it, instead of the one that you can run from a single 20 amp breaker.
The only limitations on tandem breakers are that the panel must support them.
Old 02-28-05, 10:53 AM
Received 1 Vote on 1 Post
"The only limitations on tandem breakers are that the panel must support them." That is to say, they must be listed for use in your specific panel model.
Juice
