receptacle material
Old 02-27-05, 07:19 AM
deereallis
receptacle material
There are metal and plastic receptacle boxes. Are there times when it is better to use one over the other?
Laurence
Old 02-27-05, 08:20 AM
TomZ1's Avatar
Talking
Generally the choice is yours. However, there may be other circumstances that dictate which you use.
What type of wire/cable is used in the system? NM (romex)? BX or other metal-clad?
Old 02-27-05, 07:10 PM
If you are running NM cable (i.e., Romex), and if the boxes will be recessed in a drywalled wall, then I recommend plastic. However, don't necessarily buy the cheapest plastic boxes you find. Spend a few more pennies and get ones that seem more substantial. Plastic boxes are preferred for most DIY jobs because (1) they are cheaper, (2) they are generally larger, which is a really big factor, (3) they have built-in clamps for NM cable (although pretty rinky-dinky), (4) they don't need to be grounded. Of all of these, the larger size is the probably most significant. You can find single-gang boxes of 22.5 cubic inches in plastic, but it's hard to find such large boxes in metal. The bigger the box, the easier it is to get all that stuff in.
Old 02-28-05, 06:55 AM
Mr Fixit eh's Avatar
You don't want to use plastic boxes in metal stud walls. The metal stud assembly should be grounded, and the easiest way to do this is by using a metal box attached with a non-coated screw. If you use a plastic box and do not ground the stud assemblies, you have the potential for the stud assembly to become energized if a cable gets pierced with a drywall screw, etc. Check out this link for details...http://www.esainspection.net/pdf/fsn/01_04_fl.pdf
Old 02-28-05, 09:34 AM
One further advantage to plastic: the screws on the sides of your receptacle can make contact with the box and there will be no shorting against the box.
Juice
