GFCI under the sink
Received 0 Votes
GFCI under the sink
I have a standard outlet under a kitchen sink. The outlet is split. Top part goes to a switch for the disposal and the bottom is on all the time for the dish washer.
My question is can I have this setup with a GFCI outlet? I didn't think a GFCI could be split or must I have two separate in order to have one controled by a switch and one on all the time.
Thanks
Thanks
Received 0 Votes
Standard GFCI receptacles cannot be split. All that you could do would be to either install a GFCI breaker or to use a double gang box and use two GFCI receptacles.
Why do you want a GFCI receptacle under the sink? There is no code requirement for one.
