Grounding a J box that contains 2 separate circuits
If I have a metal 2 gang J box with two duplex receptacles installed and the receptacles are on different circuits should I pigtail the ground wire from both circuits to the box?? Or would using the ground wire from just one of the circuits be sufficient??
Thanks
Thanks
The grounds should be connected together and connect to the metal box and each duplex. You may need pigtails to accomplish this.
