door bell question
Old 03-15-05, 04:39 AM
door bell question
Would like to know if I could add a second chime in a remote location of the house, using a single door button, or would that require a higher rated transformer. If so how many volts? Thanks once again for your help!
Old 03-16-05, 01:34 PM
I guess nobody really likes doorbell questions.
Find your doorbell transformer. It's usually in the basement. Find a label, or test with volt meter, to determine voltage. It will be DC. Find a chime that is the same voltage. the chimes usually take such small current that the existing transformer will power both the existing and the new chime unit.
You will probably have to pay attention to which wire is positive and which is negative.
Hope that helps.
Juice
Old 03-16-05, 07:21 PM
Actually, a transformer transforms voltage from one level to another. A rectifier converts A C to D C. The output of the transformer will be A C
Old 03-16-05, 07:25 PM
Sorry, I forgot to answer your original question. One major chime maker recommends a 24 volt 20VA transformer for multiple chimes.
Old 03-16-05, 07:41 PM
I'd try a 16-volt 20va or 30va transformer. 24 volts might be a bit much for the skinny wire, especially if your doorbell button sticks down and it draws current for an extended time.
Old 03-17-05, 10:23 AM
John,
Just reading from the catalog of my former employer aka Nut One. 16 volts should be fine but they do suggest the 24 v model for multiple chimes.
Old 03-17-05, 11:37 AM
Goldstar, what do they suggest for wire size?
Old 03-17-05, 02:24 PM
They don't list a size for the 24V model but do say that their 16V 30 VA model can also be used with multiple chimes. They recommend / sell 18 gauge wire for the chimes. Their transformers also have a thermal switch to kill the secondary if a prolonged overload is detected. Like many things, we once built the transformers and chimes in Cincinnati, but now it's all produced off shore.
Old 03-17-05, 06:11 PM
If you have 18-gauge wire, I'd say okay to the 24 volts. But a lot of doorbells are wired with something closer to 24-gauge wire.
Old 03-19-05, 05:42 AM
Thanks all! Iwas out sick for a couple off days, but will check the voltage and wire size next trip under the house.
