3Way switch install, works but lights are dim.
I have my 3way switch hooked up this way.
http://www.handymanwire.com/articles/3wayswitch.html
But i have 2 lights instead of just one like is shown on that first layout. lights turn on and off fine but they are like half power. how do i hook up those 2 lights at the beginning of the run without draining half the power? do i have it daisy chained?
Thanks all!
Thanks all!
You have almost certainly wired your two lights in series instead of parallel. The black wire from light 1 and light 2 should tie together and the white wire from light 1 and light 2 should tie together. You then effectively have one white wire and one black wire that supply the light fixtures in parallel. If you need more information, list all of the wires in your boxes.
epic69,
You must have it wired in series, as was stated. If you haven't figured it out yet then tell us how you did connect the wires and we will sort it out for you.
That picture only indicates one light fixture, so it can't be wired exactly as you say. The second light fixture is the key problem here, so the details about that one are important. If you could list the wires in each box and what they connect to, the solution should be pretty easy.
OK the first light is wired just as shown, the second light has the #14-2 wire coming in from the first light and has the white wire connected to the negative terminal on the light, the black wire coming in from teh first light is connected to the white wire going to the first switch. the 14-2 wire going to the first switch has the black wire connected to the positive terminal of this 2nd light, the white wire (coded hot) is connected to the black from the 1st light.
There is no such thing as positive and negative when dealing with alternating current (ac).
Connect the second light in parallel with the first light. In other words, connect the white wire for the second light to the white wire of the first light, and connect the black wire for the second light to black wire of the first light. Connect all bare or green ground wires together all the time.
Looking at the picture and reading your comment, I would say you still have it wrong.
May this wording will help.
From the drawing.
all you would need to do is, from the first light extend (add 14-2 wire) the white and black wires to the white and black wires of the second light, black to black and white to white.
And ground wires.
From the drawing.
And ground wires.
Just so we're clear...
I'll use "=" to mean 14/3 and "-" to mean 14/2.
The following can never be made to work, no matter how you connect it:
Power-L1-L2-S1=S2.
I'm thinking that the above is what you have now.
So you need one of these instead.
Power-L1=L2-S1=S2, or
Power-L1-S1=S2, and L1-L2.
The second of these is what is being talked about so far in this thread.
Power-L1-L2-S1=S2.
