GFI Reset Problem
Old 03-25-05, 05:49 AM
GFI Reset Problem
This is a followup to a post from yesterday.
A circuit in my house is down but the circuit breaker has not been tripped. Per the suggestions from yesterday, I found a GFCI outlet that is in the circuit. Nothing is or was plugged into the outlet recently. When I try to reset or test it nothing happens. I have used the outlet numerous times before so I know it worked at some point.
I was planning on replacing the outlet, but do these things "go bad" over time? Is that what is pulling the circuit down?
Old 03-25-05, 06:58 AM
If you cannot reset a GFCI receptacle then either there is a true ground fault or the receptacle is bad.
Yes, receptacles do go bad. However, before replacing it make sure that there isn't a ground fault. Does this GFCI receptacle protect other downstream receptacles? If so, where are they located? have you inspected them? Where is this receptacle located?
A common cause of a tripped GFCI is water in an outside receptacle. This can be fixed by drying the receptacle. Using a hairdryer can speed up the drying process.
If you replace the GFCI with a new one, and there is a ground fault then the new one won;t be able to be reset either.
If you are following up a previous post then you should continue the thread, not start a new one.
