How to find load for breaker
Old 03-25-05, 08:12 AM
Beeek
Question How to find load for breaker
I have mapped out my whole new construction house for the breaker box. Several (~50%) of the items were mis labeled. I have replaced all the back-stabed residential outlets with commercial, construction, or hospital grade outlets, and all swtches with commercial grade. So I know every circuit, outlet/switch tested to be dead b4 replacement. Every appliance I have rewired or checked (found dish washer hard wired with no NM connector just the wire passing through a sheet metal hole (grometless)). I know everything in my house very well, given my basement appliances there own circuits. Even found an addtional run into my kitchen w/ nothing attached to it, and no voltage via voltmeters voltage sensor.
But one breaker remains with nothing apparently connected to the circuit. It is wired, up, but I can't find the load. I thought it was the attic fan, but yesterday I found that to be off of the master bed branch. It was labeled once as bedroom #2, but now bed#2 is jumpered off of my loft's branch. I disconnected the jumper and started individually testing and disconnecting the outlets/switches in bed#2. I can't get the curicuits to overlap, I.E. I can't find a feed into those circuits except for the jumper from the loft. When I cut the loft everything in the bed#2 dies as well as the loft. When I cut the breaker in question, I loose nothing.
Any tricks that this hack doesn't know about that you pros do? I am willing to buy hardware, the thought of an unknown circuit is driving me nuts. The 14/2 from the 15 amp mystery breaker appears to head into the area that my upstairs beds take into the back wall of the house. My buest guess is upstairs.
Should I even be worried about this, any suggestions as to something it could work that I just over looked:
Not:
Outlets
Lights (1st floor, 2nd floor, baths, kitchen, Garage, basement, etc)
Water heater
furnace
sump pump
Outside/basement GFI
fire alarm/door bell
dishwasher
fridge
microwave
electric range (duh) even an auxilary
washer
dryer
attic fan
whirpool tub
Only other wierd item is there is a bare (no faceplace) receptacle in the back of my gas fireplace, but when I put a tester in it, it came up no voltage.
TIA,
Beeek
Old 03-25-05, 08:21 AM
Leave it turned off. Verify that there is no voltage at the output of the breaker, which would indicate a crossed circuit. Someday you may actually find something that doesn't have power.
