new garage
Old 04-03-05, 10:44 AM
zingerb
new garage
I am trying to wire two gfi 20 amp circuts from my 100amp panel by using two 20 amp breakers and runing 3 wire 12 gauge wire. the red wire for one circut and the black for the other I am also trying to protect an addtional non gfi wall outlet on each circut but when i wired it up the first gfi trips. any ideas out there.
Old 04-03-05, 11:11 AM
Snape
Have you checked that you have wired the GFCI correctly and not connected the incoming power to the load side.
Old 04-03-05, 11:41 AM
You can not use the load wires on GFCI witha multiwire circuit. You must only use line terminals.
Old 04-03-05, 12:26 PM
zingerb
Smile new garage
thanks joed I rewired and all tests good thanks
Old 04-03-05, 02:22 PM
I hope that you made sure that these breakers use opposite sides of the incoming 240 volts. If you used the same leg of the service then you have a serious fire hazard.
