Garage Electrical
Garage Electrical
I have a newly built home but one of the walls in the garage is not finished. My plan is to run two new outlets before I insulate and drywall that one wall. However, I am running into a couple of questions
1) Is it ok to use Romex behind the drywall or should I use something like flexible conduit. ( The overall length of the combined two outlets is something like 15 feet
2) If I do use Romex – when the Romex feed drops down into the basement I am probably going to switch to conduit. Can I run the Romex in the conduit in the basement or should I change the wire type in a junction box
If NM type cable is allowed where you live (and it is most places in the US) then you can run the NM inside the drywall and in the basement.
I would not switch to conduit in the basement unless you have a compelling reason to do so. You really shouldn't run NM cable in conduit unless it is for a short length and only for protection.
