whirlpool tub 240 3 or 4 wire
Old 04-04-05, 04:53 PM
map686
I am installing a new kohler whirlpool tub model K-1457-G. My question is do I run 2 or 3 wire 240? There literature is vague. any help would be great. Thanks, MP
Old 04-04-05, 07:40 PM
Install the four wire regardless of what is actually required. Someone in the future (and it could be you) may change it and need that wire eben iof you don't need it now.
However, you will need the directions to determine what size circuit you need, so you need to figure out how to read them.
Old 04-05-05, 03:44 PM
dhop
You need to know whether the neutral connection is required in the tub. I would suspect that it is needed (for controls?). Look at the wiring diagram to determine.
