220 volt blues
Old 04-13-05, 12:50 PM
ricknks2000
220 volt blues
i have a 220v table saw that used to be in a great workshop and now that we moved is in a garage with no 220. the panel is full and there is one subpanel for a hot tub that the wife thinks is more important than a saw. is my only choice running another subpanel or is there an"easy" fix. The saw would only be use once a month if that. Thanks in advance,rick
Old 04-13-05, 12:54 PM
Will your panel accept tandem or mini breakers?
Old 04-13-05, 02:27 PM
ricknks2000
sure will,rick
Old 04-14-05, 07:51 AM
Replace two of the 120 volt full size breakers with tandems. This will allow you to free up two full size spaces where you can install a breaker for a sub panel.
