Circuit Breaker Question
Old 04-21-05, 02:21 AM
Is it possible to wire a breaker backwards on purpose. What I mean is on a sub panel, the first breaker a double pole 60 amp, snap it in and put the feed wires where the output wires should go so they feed the two power bars. Would that work? if so, would that 60 amp breaker trip if there was a problem?
Thanks.
Jim
Old 04-21-05, 02:53 AM
Received 1 Upvote on 1 Post
Yes and yes.
Old 04-21-05, 03:06 AM
R
Note that this probably won't work for a GFCI breaker, at least not a new one.
Old 04-21-05, 11:50 AM
Fred373
Why would you want to do that?
Fred
Old 04-21-05, 01:10 PM
F
My relatively new Siemens 100 amp breaker box is set up exactly that way.
