grouding
Old 04-21-05, 11:17 AM
grouding
Putting in a new panel at a cabine. The water lines are all plastic and the water is supply by a well. Will two ground rodes be ok. since the water lines are plastic. This is at cabine,do i have used the pump some how as a second grounding system, the pump is about 20 feet away.
THANKS FOR ANY HELP.
Old 04-21-05, 03:31 PM
Speedy Petey's Avatar
If the water lines coming in are plastic as is typical with a well the two rods are all that's required. Actually one may be OK, but most folks put two to avoid having to prove the 25 ohm requirement.
Is this in Canada? I detect a French accent in your writing.
If this is so disregard my advice and wait for a CEC pro to chime in.
