Thermostat Wiring Question
Old 04-21-05, 05:00 PM
Installing a 220V baseboard heater. I have this double pole (4wire) line voltage thermostat with 2 black & 2 red wires. I see the wires are stranded. Do I twist the stranded together with the solid wire? Never worked with stranded before.
Also, this is a wall mount thermostat. Necessary to cut a hole in my bedroom wall. I'll have 2 red connections, 2 black connections and 1 ground connection. How large (cu. in.) box is required? I bought a box for 'old work' but I see it's 14in. Sufficient?
Old 04-22-05, 01:07 AM
What size wire is required?
Old 04-22-05, 03:22 AM
Heater is 220V 1500W supplied with 12-2 with Ground
Old 04-22-05, 03:39 AM
Yes, 14 inches is sufficient. You have five conductors, 2 black, 2 red and the grounds (all grounds count as 1).
Old 04-22-05, 10:58 AM
No, 14 cubic inches is not sufficient.
Using external cable clamp(s) in a steel box or a plastic box with built-in clamps, the box will need to be at least 15.75 in.³.
Using a steel box with an internal clamp(s) the box will need to be at least 18 in.³.
Old 04-23-05, 06:50 AM
Got a 18in³ plastic box. First supplier only had the one option as far as 'old work'. Looked fine until I got it home and saw '14' in the bottom.
Bigger box says up to 8 - #12 wires. Smaller one doesn't say. I assumed 14in³ would be OK, but since I now have this 18in³ I'll use it.
So do I just twist stranded & solid wires together with wirenuts?
Tanks.
Old 04-23-05, 11:33 PM
Hi bolted, could you tell me how you come up with 15.75. I cannot come up with that number no matter how I play the game.
Old 04-24-05, 02:10 AM
Skramy,
When mixing a solid and stranded together, I find it easier not to pretwist. If you try and pretwist, the stranded will often just wrap itself around the solid which can prevent the wirenut from actually biting into the solid conductor. Either way is OK, just a personal preference.
Morning Bob,
12/2 in counts as 3 conductors
12/2 out counts as 2 conductors
T-stat counts as 2 conductors
Old 04-24-05, 03:09 PM
Bolted,
I agree with the 12/2 and 12/3 wire count. I didn't count the thermostat wires...
