How many wires can a box hold?
Old 04-22-05, 03:58 AM
Smile How many wires can a box hold?
I have a 32 cu-in double gang box (the deepest box I can get from HomeDepot) that will hold 2 3-way switchs, now that there are 6 cables entering this box:
2 12/3 cables for the 3 way switches
2 12/2 cables going to the lights controled by these switches
1 12/2 cable for power feed
1 12/2 cable brings power to the receptacle box underneath this box
My questions is can all these wires fit in the box? Thanks.
Old 04-22-05, 04:08 AM
By my calculations you have exceeded box fill requirements.
My suggestion is to run the wiring differently.
Old 04-22-05, 04:23 AM
Can you please give me some more details on how the box fill requirement is calculated? Thanks.
Old 04-22-05, 04:25 AM
pcboss's Avatar
Received 35 Votes on 30 Posts
You would have the equivalent of 19 wires in this box. Each switch counts as 2 conductors and the ground would count once.
19 x 2.25 = 42.75 cu. inches.
Old 04-22-05, 08:38 AM
Impala*SS's Avatar
The technical info for volume calcs can be seen here
As someone who just had the same problem, I will tell you what the experts here at the forum suggested, if you can make it work....
Run power to lights first, then 12/2 to each of your other 3-way switches - then a single 12/3 to each 3-way at your referenced box is all you will need to provide a loop between each of the two sets of 3-ways.
One item that folks seemed to have different opinions on was whether to add a conductor count for the internal clamps (even though they're skimpy) that are present in the 2-gang box. Since the manufacturer's info says to count it, I did. This would bring your total conductor count to 20.
