lots o' wires
Old 04-23-05, 07:41 AM
mojorisin
lots o' wires
just trying to replace a light fixture here. upon removing the old fixture, found three 3 wires in the box, one is from a gang box outlet on the wall. never had a problem hooking up lights before but this one has me stumped. what is the red wire for? hooked up all blacks and whites, hooked red to the fixture ground, and now the light works but the switch does not. Please help.
Old 04-23-05, 07:49 AM
Try connecting the Black fixture-lead to the Red wire, and the White F-L to the White wires.
Good Luck & Enjoy the Experience!!!!!!!!!!!
Old 04-23-05, 08:01 AM
mojorisin
thank you very much. that worked. what is that red wire for, i guess its the switch but i have never seen one before. thanks again
Old 04-23-05, 11:35 PM
A red wire should be a hot wire. It should never be a ground wire. Most people will use a red wire for a switched hot.
Old 04-24-05, 12:07 PM
Connecting a red wire to a grounding wire is a fairly serious suicide attempt. Never, ever, ever, ever do it.
