tub wiring
Old 04-25-05, 03:51 AM
glennia
tub wiring
have a Lyon's corner whirlpool tub--new but no how to wire directions!! has a 3 prong cord only, no on/off switch. circuit box has a GFI that can be used but how do I install this thing?! checked where i got it with their suggestion to contact Lyon's. cant find them on internet. any help appreciated.
Old 04-25-05, 03:53 AM
pgtek's Avatar
hi
get a timer with for it and connected it to that.
cheers
pg
Old 04-25-05, 09:28 AM
Speedy Petey's Avatar
I have never seen one without a switch. Most have an air switch on the deck. This is a plunger type button with plastic tubing running from underneath to a mechanical air actuated switch.
A timer may be code in your area. I will say I haven't seen or done a wall timer in a long time. The ones I do see are mostly in modulars.
Just run a 12/2 circuit to under the tub. Install a regular receptacle and put the circuit on a GFI breaker. You of course need an access panel in case service is ever needed, and to comply with code.
If there truly is no switch, you will need obviously to put one somewhere.
