electrical box options
Old 04-27-05, 04:26 PM
Hi,
I currently have a vanity light in the washroom (on the wall). The wires go directly to the light and the light is fixed to the studs (no lectrical box at all).
I want to change the light, but the new model requires a box in the wall (because this one can't be screwed directly to the studs.... must fasten to a box). My question is: does it matter if I use a standard (round) light box, or can I use a rectangular switch box?
The reason I want to use a rectangular switch box is because where the box needs to go (for the light to be centered, etc....) there is a vent pipe taking up some room (It runs parallel to the stud with a spacing of about 2.5 inches). I can't fit a round box in the provided space, but I think I could get away with a rectangular switch box. But I don't want to do something that's against code or dangerous.
Thanks!
Mark
Old 04-27-05, 04:45 PM
Doesn't really matter. A round box is slightly more typical for lighting fixtures, but most fixtures are designed to be mounted on either.
Old 04-27-05, 04:53 PM
What your saying was a common installation in Knob and tube wiring.
Do you feel confident in describing your wiring?
Can you recognise romex?
The advice is similar but not the same.
It's not against code or anything is it?
Does Reply #3 apply to this message or is it an error?? Cause I don't have a clud what he's saying.
Thanks for the fast reply!
Old 04-27-05, 04:57 PM
I forgot to ask also:
The house is brand-new, built that way.... Is it OK that the electrician who did the work didn't install a box? I was under the impression that any light, switch or receptacle HAD to be installed with a box. What are the rules on this?
Old 04-27-05, 05:07 PM
Bathroom vanity lights are commonly installed without a box. The fixture provides a wiring compartment inside the fixture (which takes the place of the box), so no splices are made in the wall.
