Help wiring 220v pump timer
Need assistance with how to replace a on/off switch with a 220 volt timer. Timer is a Tork 1104 that has four screw terminals.
Thank You
Ron
Thank You
Ron
More info please
Thanks for your help. Is the thrid leg the ground. I show three legs coming off the box. All 3 are fused and I didn't know a ground would be fused. The three(red off left side, blue in the middle and black on right side) The motor has the same combination going to the present switch with the third leg boing to L3. Does this timer(Tork 1104) work with with a 3 phase motor?
Thanks again.
Ron
Thanks again.
Ron
