Hot Tub Wiring Code
Old 05-01-05, 09:45 AM
gsiciliano
Hot Tub Wiring Code
I hear that it is now code (Ontario Canada) that a quick disconnect is required outside the house , no different than the A/c unit. Is this correct?
Old 05-01-05, 10:02 AM
Do you mean a whole house disconnect? I have not heard of that rule.
Old 05-01-05, 10:05 AM
gsiciliano
No a quick disconnect for just that circuit. This eliviates the need to go into the house to turn the circuit off when working on the hot tub.
Old 05-01-05, 11:22 AM
Speedy Petey's Avatar
I don't know about Canada, but this is a common code in the US. Most any piece of equipment needs some sort of local disconnect. Of course there are exceptions to the rule, but for spas we do have the requirement.
Old 05-02-05, 12:43 PM
I missed the hot tub part of the question in the subject line.
I can say I don't know for sure.
Old 05-04-05, 05:33 AM
ElectricalMan's Avatar
Here in VA we usually install a circuit breaker GFCI 60A disconnect near the hot tub and wire it direct from the disconnect. We also own a spa dealership and have been wiring them in VA this way for years.
