Pre wire
Old 05-01-05, 09:51 AM
gsiciliano
Pre wire
I have an opportunity to run wire in my basement (we are presently finisihing the basement) to the outside for a hot tub. Not sure what size a tub we will be getting at this time. What is the best thing to do so that we are ready with the electrical when we decide to go with the tub?
Old 05-01-05, 10:01 AM
Received 1 Upvote on 1 Post
Run 1" PVC conduit with a pull rope in it. You can put the wire in later when you buy the hot tub and know its exact requirements. It will probably end up being three copper #6 plus insulated ground.
Old 05-01-05, 10:19 AM
gsiciliano
John what type of pull rope?? Any concerns on the run and the number of 90's on the PVC tubing. Looks like I will have 3X 90 degrees and 50 feet of run. Any chances of losing the pull rope when fishing the 6 guage wire over this distance?
Old 05-01-05, 10:23 AM
Any kind of rope will do. Something you can pull pretty hard on without breaking it. But if the rope you install today is too light for the job later, you can always use the rope you put in today to pull a heavier rope through later, and then use that rope to pull the wire through. Even if the rope breaks, it's not fatal, since it's not that bad to put in a new rope by sucking through some new fishing line later.
Three 90s isn't bad. Four is the most allowed. Gentle sweep 90s will help. The more bends, the larger conduit you might want to use to ease future pulls.
Old 05-01-05, 10:31 AM
gsiciliano
Assuming that I get a PVC conduit large enough, can this be used to pull other wires for other uses in the back yard, or does it have to be dedicated to the 6 guage wire for the hot tub?
Old 05-01-05, 12:43 PM
As long as you limit yourself to no more than 9 current carrying conductors in one conduit, and as long as the conduit is plenty big enough (using no more than about half the capacity), you can put more wires in.
Old 05-01-05, 01:03 PM
gsiciliano
Thank You. All thst's left to figure out is where to place it.
Old 05-01-05, 01:51 PM
R
N ote that you are not allowed to run low voltage cables in the same conduit (such as TV/Cable, telephone, intercom, computer, etc). Nor should you, even if it were allowed.
Old 05-01-05, 02:19 PM
gsiciliano
Good point Bob. I was just thinking that same thought.
