Is it considered an upgrade in kitchen?
If I switch the location of the frig with an electric oven I must move the power box for oven to new location. Of course I will use j-box if needed and run new wires to new location. This is a dedicated 220V circuit for the oven. Is it considered an upgrade in kitchen? If it is then do I need to upgrade all other circuits in kitchen to meet the codes? Thx.
This is probably not considered an upgrade to the kitchen.
However, if you run a circuit for the refrigerator you will need to make it up to code.
More importantly, you will probably have to make the new run for the stove up to code, which means a four wire circuit. The existing circuit may only be three wire, which is no longer allowed for new installations.
The frig was on its own circuit. I just moved the outlet. Is this OK?
Generally, I put in new kitchen cabinets, rearranged oven, and frig as in the first question. Just moved the receptacle for frig and box for oven. Does it require up-to-date circuits for kitchen?
I might have to change my answer.
New cabinet, new countertop might mean you need to bring the electrical up to code. It depends on the inspector. Do the cabinets have the same footprint, or did you change that?
Also anyone can brief me what is in the National Electrical Code, NFPA No. 70?
Thanks.
The 3-wire circuit for the range would be okay if you didn't want to move it. By moving it, you are required to upgrade it to the newer 4-wire circuit.
It's really a code technicality. The existing installation is okay, because it met code when it was installed. Now that you want to re-install it, you have to meet today's code.
The cooktop isn't the issue, it's the receptacle you plug the cooktop into. If you leave the receptacle the way that is originally was, then it's okay. If you move the receptacle, then it needs to be upgraded to 4-wire.
