2-wire vs. 3-wire
Old 05-16-05, 10:49 AM
pmazzola57
2-wire vs. 3-wire
I live in a home that was built in 2001. I just purchased a Smarthome switch that has three wires plus a ground wire. When I opened the switch box, the switch there only had two wires plus a ground.
Based on posts I've seen on other forums, two wire is old technology and I am little concerned that my house was not built to code.
In any event can I get a primer on what the three wires are for, and is there a way to make the 3-wire switch work on my 2-wire system?
Old 05-16-05, 12:41 PM
Two wires plus a ground is for a switch loop. It is not "old technology". There is nothing wrong with it, and sometimes it is the best way to run a circuit. Whatever you read on this other web site is incorrect.
The main disadvantage of a switch loop is that there is no neutral wire present. This means you canít tap the switch for an additional receptacle or light from the switch.
Refer to the documentation for this smart switch. Determine what the three wires are for. If one is for a neutral then you cannot use this switch. If, however, the switch is designed for three way operation then you can use it. The directions with the switch will tell you exactly how to connect it.
Old 05-16-05, 12:49 PM
Did you purchase the Smarthome 2 way dimmer? A neutral is required which appears not to be present in your case.
Were you looking for X-10 capability or just replacing a single pole switch with a dimmer?
Old 05-16-05, 02:43 PM
For a switch loop (no neutral) you need to get something like this:
http://www.smarthome.com/2384w2.html
Old 05-16-05, 03:37 PM
Speedy Petey's Avatar
It's amazing how much wrong and misleading information is out there on the web.
Old 05-17-05, 02:15 AM
Skapare's Avatar
Some people may be counting the grounding wire when they say 2-wire is old technology. They would say it is 3-wire if there is a grounding wire present.
When referring to the wires, don't count the grounding wire in the number. That wire is required virtually everywhere, so it should just be there no matter what. If you want to make it even clearer to others, you could say "2-wire plus ground" instead of just "2-wire". Cable nomenclature will refer to this as "14/2" or "12/2" (it does not count the grounding wire, though older cables might indicate ground with an added "G" or "+").
