Partial Voltage?
Old 05-16-05, 02:16 PM
kmcormier
Partial Voltage?
I am replacing a ceiling fan. Prior to installing the new fan, I checked the voltage of the wires. With the wall switch in the off position, the power wire still reads 70 V to ground. With the switch on, it jumps to 120 V. Is this normal?
Old 05-16-05, 02:32 PM
If you're using a digital voltage meter, you're seeing "phantom voltage". It is a false reading inherit with digital meters. Get a cheap light-up neon tester for basic testing.
