A/C Unit
Old 05-30-05, 09:55 AM
mgar
A/C Unit
I purchased a 240 volt A/C unit. I have it on its own circuit on a 20 Amp breaker, the wire size I have is 14/2. The problem I am having is that there are only 120volts going to that outlet. How do I increase the voltage to what I need to run the A/C unit?
Old 05-30-05, 10:00 AM
You are going to need to run a new number 12 wire just for this unit right to the panel.
Old 05-30-05, 10:02 AM
14/2 is a fire hazard on a 20-amp circuit.
However 12/2 can be used to provide 240 volts if connected to a double-pole 20-amp 240-volt breaker in the panel. You'll also need a 20-amp 240-volt receptacle.
Do you have much electrical experience? Did you run this A/C circuit yourself?
Old 05-30-05, 10:28 AM
mgar
A/C Unit
Thank you for your quick repies. It won't be too hard to re-run the wire. I've had some experience wiring in outlets and switches, I just haven't had to wire in a 240 volt device before. I am going to use the circuit that was used for my old swamp cooler, so all I am going to do is re-route the circuit to where the A/C unit is. Just a side note. The A/C unit is a window mount unit. Thanks again, Mike
