creating new 240 volt outlet.
Old 05-30-05, 01:57 PM
joie
I currently have a gas stove top that of course has 120 volt power run to it but I would like to change it to an electric cooktop that will require 240 volts.
Does this require running new or additional wiring or is it a matter of connecting the existing wire to 240 volts at the breaker box?
Old 05-30-05, 02:15 PM
pcboss's Avatar
This would require a new 4 wire cable to be run from your panel. Do you have 2 adjacent spots available in your panel?
The current wire is too small and does not contain enough conductors in it.
Old 05-31-05, 06:54 AM
Depending on distance and access, it may cost more for the electrical work than for the new electric range. Considering that most people with electric ranges would rather have a gas one, you might want to consider how badly you really want an electric one.
