Dishwasher PF warning...weird
Old 06-01-05, 06:43 PM
jcvilla75
HI,
I have a 15 yr old Lady Kenmore dishwasher, kept failing for 6 months on and off - and showing PF sign, stopping half way through the cycle (any cycle)...so, plugged it into extension cord on different outlet and has now worked 3 times in a row..
may be a stupid question, but why would an outlet do this, it works fine for the incinerator food disposal...
also, if i switch the plugs, the incinerator runs full time, even without being switched on - somehow seems to have constant current to it?
thanks
JC
Old 06-01-05, 07:21 PM
Your receptacle is likely wired as half switched, half constant on. This is typical, and should not surprise you.
There could be a loose connection at the receptacle. I suggest that you examine the wiring at the receptacle and make sure all connections are sound.
However, don;t do this unless you know what you are doing, as electricity can kill and cause fires.
