switch question
switch question
Can I use a 3 way switch to replace a single switch, just leaving the common terminal empty?
Connecting the power feed to the common terminal and the switch leg to one of the other two terminals will make the switch function like a single pole. You should really only do this if you can't get your hands on a single pole switch for whatever reason.
lol...Bolted.....thats funny stuff...lol....
Anyway...Lou..yes you can but not sure why since a single pole might set you back about 78 cents at a local mega hardware store but just use the common and one of the other ( traveler ) screws.
