GFCI outlets
Old 06-10-05, 05:54 AM
lmacaw
GFCI outlets
have gotton 15 amp outlets and breakers, but am running under house, attaching to 2by 6. what type of wire would be used for this,ground contact?or can you use 12/2nm.
Old 06-10-05, 06:21 AM
It sounds like this wire is outside, which means that you should be using UF rated wire.
