question about KING thermostat wiring
Old 06-16-05, 09:31 AM
frhrwa's Avatar
I have a King model S22W single pole thermostat that I want to use in my bathroom to replace the wall heater thermo that is there presently.. (it has 2 wires, blk/red)... the King has 3 wire, blk/red/white?... the drawing on the box shows only the 2 blk/red going to load and line and doesn't show the white, and it doesn't work.. so I guess the white has to be connected to something?.. thanks..
Old 06-16-05, 10:15 AM
Look at the schematic:
http://www.king-electric.com/prodtem...odID=TSTAT_SDP
Old 06-16-05, 10:16 AM
Where was the white wire connected on the old thermostat?
Where is the white wire connected at the heater?
Old 06-16-05, 11:01 AM
Could it be the old thermostat is 240 volt and the new is 120/240 volt?
Old 06-16-05, 12:11 PM
frhrwa's Avatar
got it... thanks
found out that the white is an aticipator lead and can be ignored.. the thermostat was just stuck after all, I pushed on the metal actuator until it started clicking and then just had to adjust the temp control and it finally works.. there was no white on the old thermo, so it had me going for a bit.. thanks for the information tho!...
