Garbage Disposal Problem?
Old 06-21-05, 06:33 PM
C
Garbage disposal has worked fine in the past, no issues.
Today, I was doing the dishes and meant to flip on the light and flipped the disposal switch instead. It seemed to power up fine. I meant to hit the light so I quickly flipped it back off.
10 minutes later, dishes were done, and I tried to run the disposal.
It does nothing but emit a low electrical hum.
Doesn't seem to try to spin at all.
Nothing even remotely hard/large was in there, so i don't imagine its jammed, and I can't see anything when looking in there. Both of the grinding/spinning pieces rotate freely.
Other switches/outlets/appliances all work fine, so no breaker seems to be tripped.
Any ideas?
Old 06-21-05, 06:42 PM
A hum is the normal symptom of a jam. Try the allen wrench in the bottom. Unplug it first, or shut off the breaker if it's not cord-and-plug connected.
