outlet add-on
Old 06-28-05, 04:59 PM
Gas
outlet add-on
I'm adding an outlet on in the middle-of-run circuit. I'll be using type NM cable. The other wiring is BX. To where do I attach the ground wires from the NM since the BX doesn't have a ground wire?
Old 06-28-05, 08:55 PM
If the box is metal, connect it to both the box and the receptacle.
