GFI Breaker Question - 2 Pole or 1 Pole
Old 07-08-05, 06:33 PM
jtfamily
I am pretty sure I know the answer to this is NO, but I want to know.
I have a 220V outdoor circuit that is not services via GFI breakers and needs to be (its a pool motor).
One 2 pole 20AMP GFI breaker is very expensive
2 - 1 pole 20 AMP GFI breakers is actually cheaper.
Can I use 2 - 1 pole's ?
Old 07-08-05, 07:08 PM
G
No.
They will trip.
They need the neutral line
Old 07-08-05, 07:11 PM
jtfamily
Thank you.
Old 07-08-05, 08:15 PM
ampz's Avatar
I'd also like to add that any multi-pole circuit must be protected by a breaker that will open all ungrounded conductors {hots} of that circuit,GFCI or standard
Old 07-08-05, 09:18 PM
5
Ditto. You may NOT substitute 2 single pole breakers where a double pole breaker is required.
