Bedroom circuit need special breakers Florida?
Old 07-09-05, 04:22 AM
trane's Avatar
I want to purchase a guardian standby generator(12,000 Kw) from HD to put on existing slab and use the propane supply installed with the gas system during construction. The electrical contractor said these (Home Depot generators)were illegal because the sub panel did not have these special breakers? Then he said he could hook up everything but the bedroom? All resposes will be greatly appreciated!
Old 07-09-05, 04:27 AM
Speedy Petey's Avatar
Is this a brand new house? If not, you DO NOT need AFCI breakers for bedrooms.
If it is, and your area requires these breakers (many do not yet) you can simply install them in the generator sub-panel. That is all those panels are, sub-panels with the transfer mechanism inside.
Old 07-09-05, 05:09 AM
trane's Avatar
Thanks for your reply
Yes it is brand new, C/O less than a month. I'm not sure we wanted to supply bedroom in the 1st place. We were just planning to operate basic equipmet during outage 1 possibly 2 refrigerators,1-window unit 6000 Btu,TV,minimal lighting (Cooktop is gas).
Old 07-09-05, 05:14 AM
That's a pretty hefty unit to supply such a small demand.
Old 07-09-05, 05:19 AM
trane's Avatar
We were going to get the 7000 Kw but we thought that if our neighbor asked for extention for a refrig that we would have a little extra for them. Your name fits well you are speedy!
Old 07-09-05, 09:28 AM
5
If you are going to feed your main panel via an approved bus transfer device, then it seems your panel should already have AFCI breakers.
If you just plan to plug in a few items, check local codes about the AFCI requirement for a temporary power source.
