Switch Problem
Old 07-12-05, 04:03 PM
bhancock
Switch Problem
Recently, my closet light went out. It is a 4 foot fluorescent light fixture. I've changed the switch. I've replaced the bulbs. I've checked the eletrical current. There is only 25 volts showing on the multimeter. What else can I do?
Thanks.
Old 07-12-05, 04:06 PM
Received 442 Votes on 367 Posts
25 volts showing where? Between what two points/wires?
Sounds like you have an open connecton somewhere on the circuit.
Old 07-12-05, 05:52 PM
bhancock
25 volts at the switch
Old 07-12-05, 07:28 PM
Received 1 Vote on 1 Post
Two, two, two. We need two points that you measured the voltage between. And "at the switch" is far too imprecise. Where at the switch?
Old 07-13-05, 05:33 PM
If you are measuring across the screw terminals of the switch, that is a useless measurement.
