black white and a red
Old 07-17-05, 10:45 AM
rcl3027
I am installing a hanging ceiling fixture. From the wall switch box to the ceiling box are 2 black (hot) wires and 2 white (neutral) wires. There is also a red wire.
What is the combination of connections I must make for the fixture to be powered and the wall switch to function?
I can connect the white to white and a fixture wire, black to black and the other fixture wire and the light works but the wall switch does not. The red wire is my problem.
Roland
Old 07-17-05, 11:35 AM
rcl3027
Solved
I have solved the confusion and found the right connections for the ceiling box.
Old 07-18-05, 02:55 PM
sandbagger's Avatar
good job. Sounds like someone either had or planned to have a ceiling fan w/light so it could be controlled from the wall on separate switches.
