ground wire
Old 07-18-05, 05:08 AM
carlmeyers
ground wire
I'm using 1/2 inch PVC for surface wiring in a garage. When using 12 gage wire with a 20 amp breaker, what size ground wire is needed? I assume bare wire is satisfactory to run with the 12 gage.
Old 07-18-05, 05:47 AM
R
For a 20 amp breaker you need a 12 gage ground wire. USe an insulated green ground wire.
Old 07-18-05, 06:49 AM
...or a 12-gauge bare grounding wire.
Old 07-18-05, 07:19 AM
R
Note: My recommendation to use a green insulated wire was because I prefer to use insulated wires when running individual wires.
Regardless, 12 gage must be used either way.
