Self Grounding Receptacle
Old 07-24-05, 06:07 PM
Bob53's Avatar
Hi, are most of the 15A receptacles (duplex) that we buy in bulk from the Big Box store considered "self grounding" when used in EMT uses. Or is it a more expensive receptacle that I should look for?
THANKS.
Old 07-24-05, 06:32 PM
In general the cheap, bulk, 15 amp receptacles are not self grounding. Personally, I don't trust self grounding devices anyway. Buy the green ground wires that come with screws and are made just for this purpose.
Old 07-24-05, 07:03 PM
Bob53's Avatar
Ceiling fan with remote Q
I am removing an existing dining room light fixture. I am replacing the plastic blue box with a metal brace & box rated for the new fan & light. The present cable is 12/2 NM (with a ground). Is that cable going to be ok? I guesss the idea of the remote control is what is confusing me. The black conductors at the switch will be connected via wire nut and I planned on just putting a blank cover back on the wall switch box. Sorry, but I will not be purchasing the fan until tomorrow, so I do not have the directions yet.
THANKS!
Old 07-24-05, 07:30 PM
You really should start a new thread for a new topic.
Your plan for the fan sounds fine.
