Wire Size
Old 08-07-05, 05:59 PM
MC-130P FE
Wire Size
I plan to run a 240v 40 amp service to my workshop. The distance from my house to the shop is 220 feet. Is # 6 wire big enough for this?
Thanks for your help.
Old 08-07-05, 07:24 PM
R
I would say no, you need to go down to #4 wire. # 6 will work, but if you really approach 40 amps, or if your two 120 volt legs are not closely matched then your voltage drop will get too large.
Old 08-08-05, 09:03 AM
T
#6 copper wire or #4 aluminum wire will work.
Old 08-08-05, 03:32 PM
On runs like that I use number 2 alumimum and put it on a 50 or 60A breaker. It keeps V drop to a minimum and is enough that a guy could run a welding machine if he had to or a air comp and some lights. 6 wire and 40 A is too marginal for my tastes, and aluminum wire is cheap. This kind of setup makes for decent motor starting also.
Old 08-09-05, 06:20 PM
MC-130P FE
Thanks for the response, looks like I will go with either #4 copper or #2 Alum. What size ground wire and conduit should I use for these?
Old 08-10-05, 07:15 AM
You can buy a 4 conductor alum (quad) feeder from the box stores just for this, has all the wires twisted together and sized for it. I think its a 2-2-2-6 or 2-2-4-6 ??? Anyway, its designed jut for this. You could go to the supply house and buy 1000 ft roll of number 2 also,, ha but the ready made has stripes, wires are marked.
Old 08-10-05, 10:07 AM
solipsist9
do yourself a favor. stick with copper.
john
