doorbells
Old 08-08-05, 03:00 PM
doorbells
is it possible to have 3 doorbells controlled from one bell push at the front door ??? and if so how cable run would be approx 70m
thanks
Old 08-08-05, 03:05 PM
Do you mean three chime units?
Yes, it's possible. But you'll probably have to upgrade the transformer from a 10va or 20va transformer up to a 30va transformer so you have enough umph to drive three chimes.
Basically all you need to do is run new doorbell wire from the existing chime unit to the new chime units, connecting the new wire to the same place on the existing chime where the old wires are connected.
You might also consider wireless doorbell chimes. Much less work.
Old 08-08-05, 03:18 PM
many thanks for your reply would i also have to upgrade the cable size due to the length of run ???
gordon
Old 08-08-05, 07:03 PM
Received 2 Votes on 2 Posts
If my math is correct, 70 meters = about 230 feet. That seems to be an awfully long run for low voltage. I'm not sure even a wireless chime would reach that distance.
