Messed up voltage on garbage disposal.
Old 08-10-05, 04:38 PM
pyro22266
I recently moved into a 10 year old house and before we moved in..everything worked, including the garbage disposal. Now it doesn't work at all. I'm getting only about 64 volts across the switch. There is a light switch for a flourecent light right next to the garbage disposal switch and its on a different circuit. It has 120 volts across it. What would cause the disposal switch to only have 60-65 volts across it? Any help here would be appreciated. Thanks
Old 08-10-05, 05:02 PM
pcboss's Avatar
Received 113 Votes on 98 Posts
First you need to tell what type of meter and where you are measuring the voltage.
Do you read voltage from hot to bare groundor hot to neutral?
Old 08-10-05, 05:43 PM
pyro22266
Multimeter
I got it working...thanks for the reply though.
Old 08-11-05, 07:25 AM
So what was wrong and what did you do to get it working? We're curious.
Old 08-11-05, 07:37 AM
R
Received 1 Vote on 1 Post
MY bet is he found the red reset button on the bottom of the disposal and reset it.
