Do I have 240v power
Old 08-11-05, 11:22 PM
I want to install a steam generator for steam sauna, which require 240v power supply.
I have a circuit breaker box inside the garage, in which there are multiple breakers for different zone's lights, electric stove (range), washer/dryer, etc. Do I have 240v power in there? How could I find it out?
John
Old 08-12-05, 01:17 AM
Yup, you have it, now its a matter of how much you have available and how much you need.
Old 08-12-05, 02:08 AM
Look at the name plate for your stove (range), I would think it states 240 volts. or if you have an electric dryer.
Old 08-12-05, 04:17 AM
Speedy Petey's Avatar
I would imagine there are only about 4-5 homes left in the whole country that do not have a 120/240v service.
You have breakers, you have 120/240.
Is there room left in the panel for more breakers? Tell us the name and number of the panel.
Old 08-12-05, 09:56 PM
Thank you, guys.
On the panel, there is company named Square D with No. QOC20W.
I saw both Range and Dryer used two breakers. And rest of light zones used one breaker only. There are planty of extra space for more breakers on the panel.
I want to add 240v is for steam generator rated 5KW.
John
Old 09-18-05, 06:20 PM
andrei
wondering how the steam generator install went...
Hi HobbyJohn,
I'm in the process of installing a 7kW steam generator.... Just wondering how your project went. Anything to watch out for, etc?
thanks
andrei
Old 09-19-05, 08:14 AM
30 amps X 220 volts = 6.6 Kw ---- #10 wire
40 amps X 220 volts = 8.8 KW----- #8 wire
