Several Questions
Old 08-16-05, 11:06 PM
montag
Several Questions
How many recepticals can I cascade off of one GFCI? They used to have an instruction sheet in them, the ones I got today don't.
Does a garage door opener count as a permanent appliance, and not require GFCI protection in a garage?
There is also a small freezer in this garage, does it have to have a single recepticle to use the GFCI exemption?
Thanks for the help.
Old 08-17-05, 04:32 AM
Sometimes a manufacturer will state how many receptacles can be run off the load side of the GFCI, but that is about all you will find, if that. Code does not impose a limit. In reality, unless you are talking about a really strange setup, you won't run into a problem in a typical home installation.
Generally speaking, a garage door opener is plugged into a receptacle mounted in the ceiling or rafters, near the opener, and therefor does not require a GFCI, since it is not general purpose.
Most inspectors would allow a non-GFCI duplex receptacle for a refrigerator or freezer in a garage, as long as the receptacle is behind the appliance and therefor not accessible for other loads. Some might require that it be a single receptacle, and just about all would require it if the receptacle were exposed.
Old 08-17-05, 09:06 AM
The only issue I see with doing this is over long distances and needing a lower gauge wire to be able to take the load of all these outlets with minimal power losses due to the wire. If you run a some sort of heavy duty motor say an aircompressor on the end of the branch with a bunch of other things being power this can pose problems. Voltage drops across the wire will pose power issues with an electric motor. For this reason I want to hunt down the electricians or engineer that signed off on this for what was done where I live and show them where my foot can fit.
