Another transfer switch question...
Old 08-17-05, 06:07 PM
scoob8000's Avatar
As some of you may of seen my last post regarding a single circuit transfer switch for a well pump.
I've been doing some more reading on transfer switches, and a small 6ish circuit switch is a lot cheaper then I expected.
I like the looks of this one: http://www.amazon.com/exec/obidos/tg...?v=glance&s=hi
It's a GenTran Powerstay 200660
Is this not a "load side" switch like others I've seen? It calls to add a 60amp double pole to your existing panel. I would need to remove either two singles or a double to make room for it. Would this switch act as a subpanel like so?
Second question, what kind of locations are suitable for such a switch? The only location I think would be suitable would be on a different (non-structural) wall to the left of the existing panel.
Sorry for the newbish questions again guys..
Old 08-17-05, 07:12 PM
Speedy Petey's Avatar
Those are nice if you need the panel space in the main as they are essentially a sub-panel.
These on the other hand:
<img src="http://www.aplussupply.com/gent/gen6lg.jpeg">
are MUCH easier to install and they don't cost any more than the breaker panel style.
Old 08-17-05, 07:22 PM
scoob8000's Avatar
Thats the other kind I was refering to. They are pretty simple looking to install..
Old 08-18-05, 06:22 AM
As an option, you may have the availability of tandem breakers for your panel, if you go that route. These fit two independant CBs in the space of where one used to be, to make room for additional circuits. Naturally, it doesn't increase the ampacity of the panel as a whole, just gives you more circuits. They also come in configurations that fit four breakers in the space of two, with the two in the middle being a 2-pole for 240V loads. Very handy when necessary.
Old 08-19-05, 01:51 PM
scoob8000's Avatar
No tandem breakers for this old panel..
If if were to get that larger switch, and suggestions about mounting locations?
-scoob8000
Old 08-22-05, 03:03 PM
scoob8000's Avatar
Bump for question about switch mounting..
Old 08-22-05, 03:49 PM
Those panels are surface mount. They do have flush mount versions as well.
Problem is the flex is no too long. Something like 12"-18", so it must be mounted very near the electrical panel.
Old 08-22-05, 06:51 PM
scoob8000's Avatar
I'm mainly wondering if it would be a code violation to have it on a different wall from the main panel. (block wall 90 degrees to the left of the main panel).
Thankie
Old 08-22-05, 07:32 PM
No, absolutely not. That will be fine.
