Reload this Page >
is there a minimun distance to the basement floor for wiring?
Old 08-19-05, 06:33 PM
I want to reroute wiring between 2 outlets in the basement.
Here is a picture of the setup of my ongoing structured wiring project:
http://www.seezar.com/pictures/wiring/wiring3.jpg
Towards the bottom of the picture you can see the wiring from between 2 outlets. I'd like to basically move it at least a foot or so closer to the ground so its farther away from all my data cables. Being that it is in a basement is there any code stating that electrical wiring has to be a certain distance from the basement floor?
Old 08-19-05, 06:36 PM
Speedy Petey's Avatar
No, none at all.
I will say, moving that one wire down is not going to make any differnece.
Are you having problems? Is this why you want to move it?
Old 08-19-05, 06:42 PM
Originally Posted by Speedy Petey
No, none at all.
I'm not experiencing any problems and though there is a chance of it causing interference I realize it probably wouldnt be noticeable if at all. If anything, my reason would be more cosmetic as it would be out of the way.
